Rhodesia's avatar
Rhodesia
2005 Lance 845
I just bought a 2005 Lance Camper with extended cab for the queen bed and it has the rear bumper. The manual says it's dry weight is 2,190 lbs and wet weight is 2522 Lbs. I have a 2016 Ford F250 Super Duty Power Stroke Turbo diesel 3/4 ton truck 6.7L it came with Air lite air springs 5000 series and a tow rating of 15,500 pounds (Trailers). I have a short bed truck due to having a crew cab and this 845 is a short bed label says Lance 845 lite 8' 6". before I bought it I had Ford dealership make sure I can carry this camper on the back weight wise that is and they conformed yes I can and the Lance dealership also said yes due to it coming off of an older Ford F250 Super Duty. To get a third opinion I took the truck down to the RV suspension shop that only deals with Motorhomes and Trucks undercarriage. They found that in order to carry this they recommended the air springs which I have already installed and Super springs Overload Leaf's, and a Rear Sway Bar since Ford does not install these on their trucks. anything else anyone out there would recommend? Because the RV Suspension Shop said if I add anything else would be an over kill for the undercarriage. Thanks for any input. as a note I have seen these Lance model 845 on a Ford F150 on a 1/2 ton truck. Lance does not specify saying what trucks this will fit.
