jbres
Aug 12, 2013Explorer
2005 ram 2500 4x4 quad vs. 2006 ram 1500 quad 4x4
I got it narrowed down between 2 tow vehicles. Both should be WELL within my towing capacity. I tow a 26' wildwood tbss travel trailer loaded down at 6,700#'s...
FIRST, I have found a 2006 Dodge Ram 1500 5.7 Hemi 57,000 miles 4x4 w/ 3.92 rear end with tow capacity of 8,500#s specs are below...
(With 3.92 Axle Ratio Axle Ratio You Can Tow 8500 lbs
Gross Vehicle Weight Rating (GVWR) = 6700 lbs
Payload = 1347 lbs
Curb Weight = 5353 lbs
Curb Weight Front/Rear = 3120 lbs/3120 lbs
GAWR Front/Rear = 3900 lbs/3900 lbs
Gross Combination Weight Rating (GCWR) = 14000 lbs )
SECOND, I found a 2005 Dodge 2500 4x4 quad cab w/ 3.73 rear end and 5.7 Hemi. Very very low miles. Towing capacity of 8,800#s
Specs are below...
With 3.73 Axle Ratio Axle Ratio You Can Tow 8800 lbs
Gross Vehicle Weight Rating (GVWR) = 8800 lbs
Payload = 2730 lbs
Curb Weight = 6070 lbs
Curb Weight Front/Rear = 3471 lbs/3471 lbs
GAWR Front/Rear = 5200 lbs/6010 lbs
Gross Combination Weight Rating (GCWR) = 15000 lbs
I am looking for Dodge owners input and advice on which truck would be better. I am upgrading so now I can ACTUALLY have control over my travel trailer, and the necessary power. The 2006 1500 4x4 was registering 15mpg when towing..? Will the 2500 get comparable?
Looks like dam near same towing capacity...
The 2005 2500 is priced lower than the 2006 1500.
THANKS!
Payload = 1347 lbs
Specs are below...
Payload = 2730 lbs
THANKS!
