ricatic
Feb 18, 2014Explorer
Redsky wrote:
There was an engine change mid-year with the 2007 diesels and the more reliable ones are the Classic or early 2007 ones with the LBZ engine. The usual problems with these engines are from fuel restrictions or fuel pressure relief failure and there are multiple aftermarket work arounds available. Usually the engine goes into a limp mode but nothing is damaged.
A fuel injector rebuild will cost $4,000 to $5,000 so if the prior owner already had this work done it makes the truck that much better and a safer buy.
This is the first time I have heard that the LBZ has fuel injector issues...the earlier models, 04 and 05 I believe, have had a reputation for fuel injector replacement. The only chronic issues I found evidence of in the extensive research I did before I bought mine were 4x4 transfer case rub and leaking transmission cooler lines. I bought a 2 wheel drive so that eliminated half of the issues
Peeps may be here shortly with more info as he is one of the guru's for LBZ DuraMaxs...
Regards
44,068 PostsLatest Activity: Jun 17, 2026
