- notsobigjoeNomad IIII do not have an Alpenlite but normally if it is prewired it is in the rear or center 14 x 14 roof vent and the outlet should be right next to it. Here are a couple of pics of my Lance 1181.
The wiring is also seen when I pull the trim out from the inside.
Hopes this helps and I have many more pics. You are in the right place. It may take some time to get the conversation started.
Joe - Grit_dogTrailblazerI'd imagine in the ceiling, at or near an existing vent or fan that could be removed to install an AC.
Do you see the wires/breaker pre-installed in the breaker panel?
