2500_Grunt
Oct 18, 2013Explorer
A set of Carli are about $800 and if you do some searching around on the Cummins Diesel forum you will eventually find out that they are the way to go. Also, don't let a shop just put a pry bar under and above the ball joints and pry them and say that they are wore out just b/c there is some movement. Have them measure the play with a dial gauge/indicator and compare to OE specs.
