Yes, the '06 6spd lly is the same as the LBZ. It has all the revisions except for the finalized tune of the LBZ. If you are still concerned, check the diesel place dot com for further clarification. Christopherglenn is also correct about reading the flash.
I'm just adding this redundancy because there was some innacuracies in earlier posts. Good luck, if all checks out, I would have no issues bumping the tune to at least LBZ stats. Neighbor has a 36', or larger toyhauler he pulls out to Glamis through hills,desert, winds, and has been doing it since '06 when he bought his LBZ. It's also raised, big tires for the sand and tuned +40hp. Desert out near Palm Springs can cook, he has had no issues. FWIW.
