time2roll
Mar 21, 2017Nomad
2700 - 3000 rpm running down the flats would be normal.
3200 - 4200 rpm climbing would be normal.
You may need 4.30 or 4.56 gears to keep the rpm up without running in 1st and 2nd all the time. The larger tires are killing you.
And yes I have run my older 5.4 at 3000+ rpm for 10 hours straight.
Otherwise if you want to run 2000 rpm you will need a diesel.
44,056 PostsLatest Activity: Nov 19, 2013
