coolmom42
Mar 21, 2017Explorer II
jimh425 wrote:
I intended to use my 2006 4.6 v8 Explorer to tow my driftboat/trailer with a few tires over the Cascades and Rockies this weekend. I hadn't even made it from Seattle to Snoqualmie Pass before I decided to turn around.
My guess is the driftboat/trailer with tires was still no more than 1500 lbs and probably closer to 1000. Those of you who tow with yours, should I expect high revs to maintain 65-70 going up mountains with this type of load? How many RPMs should I expect up to 6000 ft?
If not, what should I check? My 2006 Limited is AWD with 18 inch wheels. The tires are slightly larger than stock size.
NOTE: I took it to Montana using a F450 instead. Obviously, a bit overkill for a light towing load.
I would not expect any 6 or 8 cylinder engine to tow much of anything up a mountain pass without some high revs, at 65 mph.
It's not a big deal to get in the right lane, shift down, and slow down. There's no need to run every mile at 65 mph.
44,056 PostsLatest Activity: Jan 12, 2020
