recycler
May 27, 2013Explorer
going from the pics you posted it looks like your unit has fiberglass sides on wood..that nose peice almost looks like it is mdf board..i would start poking at the edges with an awl to see if it is glued together or just held by the trim...the new frame you showed is built from peices of plastic/wood composite like used in decking or painted wood and appears to be fairly simple..it takes some time to figure out how they put it together.. best of luck and it can be done
