NRALIFR
Jan 01, 2014Explorer
2001 Lance 1121 Rot Repair
Update 05/02/2020:
This is a topic I posted in 2014 detailing the replacement of the two rear skirts on a 2001 Lance 1121, which is an all-wood frame camper. After the skirt replacement, I then covered the underside of the wings, and the sides of the tub with FRP. I still have the camper, and I’ve replaced the black truck with a red one, so I’ll post some current images at the end showing how well the new skirts have held up.
The image links in this topic were broken a few years ago when photobucket decided they were no longer going to allow image hosting for free accounts. When they did that, they ruined many of my old topics that had images imbedded, and there were just too many to go back and fix.
I was asked a few days ago by a forum member if I could restore the images to this topic, as he was about to start a similar repair on his camper. I just finished fixing the links and have bumped it to the top so it will be easier to find.
I have to warn you, you’re going to encounter a little whining about some shoulder injuries I was working through at the time. I’ve since recovered from those, thank goodness. Not “as good as new”, but good enough.
Another reason I bumped this to the top is, updating these old topics with new image links isn’t the easiest thing to do. Especially using an iPad, that doesn’t show you the image names like a PC does. But.......I suffered through it, and now you will kindly read every word and savor every image............please! :B
Also, it’s my understanding that you can no longer buy the replacement skirt kits from Lance, at least not for a camper as old as mine.
I've been working on my camper since after Thanksgiving, replacing the rotted panels on each side next to the bumper. This is a pretty common repair on the older wood framed Lance campers. Doesn't seem to matter if it's a filon or aluminum skinned camper, they all seem to need this repair eventually.
So first of all, what are those panels called anyway? I always thought they were called "skirts", but when I was removing the old filon skin, I found hand-written on both: "Drivers/Passenger side A Wing". I assume the person who built them at the factory wrote that. Since they hang down, "skirt" seemed the appropriate term to me. I always thought the "wings" were the parts that extended out over the sides of the truck bed. Whatever..... I think I'll just stick with the terms I've always used for this topic.
Despite being fairly vigilant about keeping the camper seams sealed up, the bottoms of the skirts have had a problem since the day I bought this camper used in '04. That's just a very difficult area to keep dry, and it's probably second only to the nose of the camper in terms of how much water it's blasted with when driving in a rainstorm. I've been fortunate that the repairs I've had to do on this camper up to now have been fairly minor. I've had to fix a couple of other small rotted areas in the nearly 10 years I've owned it. One was a very small area under the filon at a top rear corner, and the other was around the fridge drain tube where it poked through the underside of the "wing" which isn't covered with filon. Both were basically just small patch jobs. The skirt panel rot appears to be confined to the bottom 8" or so of the panels themselves. There doesn't appear to be any water damage to critical structural areas of the camper (most importantly the jack mount areas), so my plan is to replace the skirts and just patch up any surrounding rotted wood as needed.
Replacing the skirts is going to be a little more involved than the previous repairs though, and knowing this I've put it off as long as I dared. I've been monitoring their deterioration by squeezing along the bottom edge where I can get my hand around both sides. Over the past year or so, the edge trim has started to loosen up as the screws lost their hold. I actually bought the new skirts from Lance a couple years ago, and had been waiting for the right time to dig into it. Now that I have a place to work out of the weather, it's time to get started. Earlier this year, I painted several coats of spar-urethane on the raw wood of the new skirt panels to give them a little better protection from the elements.
These are the old skirts and filon panels. Pretty rotted on the bottoms, but we've all seen a lot worse haven't we?. I was happy to see that the rot hadn't gone any higher up than I suspected.
The cavities that were filled with fiberglass insulation on the old panels will be filled with blue foam board on the new panels.
These are the new panels. The one on the right is the passenger side panel where the storage compartment is located. The one on the left is the driver side panel where the dump-valves and outside shower is located. The upper half of this panel is also the inside wall of the bathroom behind the commode. I'll explain the two holes connected by a straight cut in a minute.
These are the new filon "skin" panels. Filon outside and luan inside. The luan side has also been coated with spar-urethane.
After removing the compartment doors and edge trim, I was surprised to find that the filon panels were simply attached with staples around the perimeter edges where the trim would cover them. I expected to find them fully glued to the skirt panel, and to really have to work at it to get off. But, after removing the edge trim and compartment doors, it came off pretty easily.
After removing the skin, getting the skirt panels off without destroying too much was a little more challenging. They're probably the last parts of the side structure to be attached at the factory prior to the first sheet of filon going on the sides. That first filon sheet is put on with it's top edge aligned with the roof of the camper. The height of the sheet is such that it overlaps the top edge of the skirt panel by about 6". As you can see in the picture below, there's a seam in the filon siding a few inches below the top of the storage compartment door.
The new filon sheets included with the replacement skirts are big enough to cover the entire panel, so apparently the idea is to cut the filon at the top of the skirt panel in order to get it off. The new filon seam will be just above the compartment door.
The skirt panel is attached primarily with screws. The scariest part of this job so far has been cutting off the 6" of overlapping filon from the top sheet to get to the screws underneath. Even after doing that, I find that some of the screws are going to have to be cut because they were driven in from above, and their heads remain hidden behind the upper filon sheet. I've found my Rockwell Sonicrafter to be an invaluable tool for this project. With the right blade, you can make plunge-cuts through all types of materials, including metal.
I found an added challenge on the drivers side where a bundle of wires from under the bathroom sink area was pulled trough the inner cavity of the skirt panel behind the commode, and then back into the area behind the shower. Four of these wires are 10 gauge for the electric jacks. Not wanting to cut the wires and splice them back together, I had to cut the old panel's interior paneling to get the wires out. They will need to be routed the same way through the new panel, so I cut the two round holes in the new panel with a hole saw, and connect them with a straight cut using a circular saw as you see in the picture above. I'll just cover the portion of the cut that will be visible inside the camper with a piece of trim. There isn't enough slack in the wires to move the bundle into the plumbing area below the commode, or I would have done that instead.
As I said earlier, the rot "appears" to be confined to the skirt panels themselves. That turned out to be about 98% true. I did also find a little rot damage on the ends of the piece of wood that runs the width of the camper at the bottom of the rear wall. There's a 2x2 piece that runs under the generator compartment door, and the rear entry door of the camper. The bumper is also attached to that piece. The lower support sockets for the folding ladder are also attached to it below the generator door. All I can actually see of this piece are the 2x2 ends of it. About an inch on the drivers side is rotted, and about 7-8" on the passenger side. The rot on the passenger side doesn't appear to extend under the generator compartment door, as the ladder sockets are still in solid wood. To replace that entire piece would require removing not only the bumper, but the generator, the compartment door, and the sheet metal compartment liner as well. The bumper is still solidly mounted, as I checked every lag bolt holding it on. With the exception of the one that screwed into the rotted area on the passenger side, all the others are screwed into sound wood. Being a firm believer in the concept of not creating more problems than you're fixing, I'm going to just replace as much of the rotted wood as I can without removing the bumper, generator, etc. If I ever need to replace that entire piece, I'm confident I can do it without having to remove the skirts again. Besides, I'd really need the camper sitting up higher than it is right now in order to work on that area. I've got the rear jacks and mount brackets removed right now as you can see.
This is looking into the area on the passenger side after removing all of the rotted wood I could.
The cavity is about 6-7" deep, and you can see an irregularly shaped piece of sound wood I was able to leave. Using the Sonicrafter with a coarse blade, I was able to hack it off to a fairly flat surface on the end. Using a bi-metal blade I was also able to cut off the remains of the screws and staples that were in this area. I considered several ways of filling this area back in, but finally just settled on using a scrap of some treated lumber cut to size and shaped to slide in as far as possible. This really wasn't as hard as you might think, considering the odd shape of the old wood left in the hole. I cut the wood to size on a table saw, made a few more cuts to get the majority of the material removed, then hand carved the rest.
This "plug" extends at least 7" into the hole, and overlaps the old wood by at least 5". When driven in with a rubber mallet it will go in all the way up to the pencil lines and it is very difficult to remove.
I set the plug in place by dampening everything with a little water, then coating every surface with Gorilla Glue. A couple of clamps help control the expansion of the glue while it dries. I'll cut the end off even with the edge of the filon covering the back wall later.
On the drivers side, I just trimmed the rotted wood off to a flat surface with the Sonicrafter and made another filler piece out of the treated wood. Shown glued into place here.
Before installing the skirt panels, I'm going to coat as much of the exposed raw wood of the camper that I can get to with spar-urethane. I've made a couple of test-fits and they both need a few adjustments to the edges in order to fit properly. Nothing made of wood is ever truly square, is it?
More later.
More later.
