Awesome work!
Good call on the FRP. I also want to cover or replace the vynal covered ply. When I had ours apart for other repairs I knew was the time, but wasnt sure if repairs were going to work so didnt redo box wings. Regretting it now because a lot of my trim was replaced with semi structual/permanent angle. Doable but need remove/redo all previous work. Suppose I could cut around existing stuff or trim to new trim, but should have taken the time, it will be 5 times harder now. Oh well.
I should let this motivate me to get on our right wing (skirt). Its getting pretty bad. Appreciate the
Brandsport link on the 2" molding. I was wondering what to do there as I know Ill need to recut the match line & the existing 1" trim wont cover. I assume its solid color allowing for the creative trimming?
New trim certainly looks to have 'blended' & helped the stark differance in filon colors. Looks good. The interim door repaint, not so much :).
