John6's avatar
John6
2001 1010 Lance truck camper Battery Switch
This is a first, I have owned the camper since 2006. The battery switch was in the off position ( which is in). I pulled the switch out, to check the monitor inside at the controls panel. All looked good, it read the battery was full and charging. (I have it hooked to a solar panel).
However, when I attempted to push the switch back ln, it was like spring loaded! It will not go back to the IN or (off) position. Also, the camper is disconnected from the truck.
Any ideas out there TIA
John
  • Thanks for the input. I like to use it when I don’t have access AC power. Cuts off all drain on the battery.
  • get a new switch and change it out, its 20 years old, or just leave it on.  I don't think I have ever used mine on my 5th wheel, it stays on year round.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
