camilllit wrote:
Thanks guys. The EDGE system does have all gauges (trans temp/egt's/fuel pressure, turbo boost, etc.
Its not overloaded because that was its wet weight when we towed it home new. We only load a few things, basement is nearly empty, all grey/fresh/black tanks empty. I forgot the factory hp was 325. FishOnOne, you are right. I'm checking into it tomorrow!
Unless you added a sending unit to the trans for the edge to read, it definitely can not read trans temp.
Stock, you truck has what is essentially a switch to turn on a dummy light when it's way too hot.
