gopherslayer's avatar
gopherslayer
2006 Yukon XL 2500 tires
Picking up this next week. Has a 6.0 and 4.10 gears. Will be Used for our camper of course. Need suggestions for tires. The ones on it are ok for the time being but would be more confident with new ones. This Yukon is 2wd so nothing too aggressive is needed. Camper gross is 8000#s if that helps.
My dad suggested masterforce which is what he is running on his 3/4 Chevy pickup.
  • This will be for fair weather use only right now. I have an 03 Silverado for daily driver with 3.73 gears and the mileage isn't the best but a little better than a 6.0 3/4 ton. I may sell the 03 and use the Yukon as a daily driver in the future. I am not going up to a 265 tire. 245 and 4.10 gears is why I am buying it. It rides nice as it is with the 245s. Weight and long wheelbase help here.
    I am leaning towards a Cooper or a Michelin, just like what has been suggested.
  • I do not recommend increasing tire diameter for the tow vehicle. The 6.0L will need all the torque multiplication it can get.
  • Will you be using it in snow? Or is this a summer only vehicle and the most it is going to see is rain?
    I have loved all of the Michelin tires I have ever had. I like the fact they have full tread depth sipes and this helps maintain traction performance even with lots of miles.
    My 1 ton Express van had Bridgestone V-Steel Rib 265 tires on it. Surprisingly, this tire was very good in the rain and even in the snow. I was on track to get at least 60k miles out of them. I am assuming my van probably weighed more than your Yukon will, so maybe they wouldn't be as great on your truck.
    Be careful stepping up a size or even two. The OEM wheels on your truck were designed for a 245 tire. Yes, there are lots of people out there that have gone to 265 or 285 tires...I can tell you I didn't like the way my 2004 2500 Suburban handled with 265's.
  • You definitely want to get a load range "E" tire. I think the original size is 245/75-16. Most people go up a size or two to a 265 or 285/75-16. The bigger tires just look better by filling out the fender well better and also ride a little smoother. What I usually do is browse sites such as tirerack.com or discounttire.com and look at the tires in the size I'm looking for and read the customer reviews. It also gives you a good basis for what you should be paying for the tires if you decide to buy locally. Good luck!
  • May be a little more aggressive tread than you want, but I was extremely happy with the Cooper A/T3's. Very good in all conditions I had them in (never tried mudding). And they have a mileage warranty.
    Is this a summer tow vehicle only, or a daily driver also? Knowing this may help with suggestions.
  • I like our Michelin LTX M/S2 tires. 25k miles already and wearing well with great grip still.
  • I had some Michelin LTX M/S that did me well before I wanted a more aggressive tread.
