silverbullet555's avatar
Jun 06, 2021
2007 Chevy 2500HD classic/superhitch spare doesn't fit.
So, we are right at 1 year since buying our truck camper. It's been quote odyssey in making it all work right together. My desire to tow the boat while the truck camper was installed has been the primary motivator for the helper springs and the sway bar. Last fall, I bought a superhitch because our boat was too heavy to just use an extension.
I finally got around to installing it and now the spare won't fit. I might be able to loosen the bolts and slide the hitch back a bit (which is a good idea regardless) and may get the tire in, but I'm relatively sure it would be hitting the diff which can't be good.
I'll reach out to torklift in the morning, but for now, I am exploring solves in order to make it work.
Curious from others that might have some suggestions or experience.
If it matters:
Truck: 2007 Chevy Silverado Classic 2500HD shortbed 4x4 duramax.
Tires: Currently 285/75/R16 BFG AT/TAKO. 50% tread
Camper: 1995 Northland 860
Possible ideas:
Put spare inside camper for traveling and take it out when we get where we are going. Major PITA, not sure it would sit on the floor nicely. Super cheap. May be required for the short term.
Put tire on roof of camper? I read that from an old thread on here. Worried that it would cause some kind of damage up there, though I don't know that it would be an issue. Downside is having to hoist it up and down when the camper is on and off. Normally, that would only be a couple times a year. Is there potential for damage to the roof under normal use? We do spend time on dirt roads in the fall during hunting season. Summer would be mostly freeway.
Deflate spare and add a compressor somewhere for on board air. Needs to be able to get to 85 PSI to re-inflate spare as needed. Upside is onboard air for inflating things, blowing out water, etc. Unsure if this would get me the space needed. Additional benefit is being able to plug a tire and reinflate on the side of the road if needed. Is there potential for other issues with a deflated spare? Cost $250
New tires: I would wait until needed and need to find a temp solution in the meantime. Switch to a 275/70/16 or 265/75/16 for the next set of off-road tires. Will need to still have the weight capacity that the current tires do to support everything.
Mount spare on front bumper using front hitch. $250 or so from my quick research. moves the weight up front is a big plus. Only concern really is temps when towing up a hill with the boat and camper. Haven't had overheating issues so nothing to base it on, but something that came to mind. Other issue is losing some visibility. Up side is I wouldn't mind adding winch to get us out of the much should there be an error in judgement. Preserves desired tire size and should be bolt on. No worries about future tire sizes, etc.
Mount spare on front bumper using welded customer bumper. I've always wanted a front bumper like a ranchhand. Could go that route, put a receiver hitch on it so I can have a winch to slide in as well. Most expensive option, but extra brownie points for the cool factor.
  • I have a very old truck and built a storage compartment in my place of my back seat. That is where I keep it. Not much help but some input. It's a good 70 pounds off the rear of the 1181 though.
  • Are your tires oversized, because my spare fit with no problem?
  • I've had two truck campers I had to get a front bumper mount tire carrier and another I just put the spare on the boat tongue..
  • Others have used front mounted tire carriers.
  • wnjj's avatar
    wnjj
    Explorer II
    Just use a smaller spare that fits. If you have an issue with a rear tire, swap a front to the rear and run the spare on the front. Odds are you’ll never need it anyway.
  • Bedlam our moderator mounted his spare on his superhitch. Not sure if it's laying flat topside or under.
