ijon's avatar
ijon
2007 diesel truck
Anyone had trouble with turbo sensors on a 2007 GMC truck? Throwing codes p0003, p2563, and p0299.
  • I threw a code twice on my 2007.5 (new body style) Silverado D/A. Once on the George Washington bridge going into NYC. The truck went into a limp mode and it wasnt a happy time. Had an exhaust sensor replaced (forget the technical name of it) and about 3 months later it happened again. My local dealer had it for about a week, so that told me they were not having alot of luck diagnosing the problem. After that I soon got rid of it. I knew I would never trust it, plus I needed a dually anyway. Seems like some of the 2007s were plaqued with code isues.
  • . . .Do you have a tuner or programmer on the truck???? Does it happen when not towing / or towing??? Is truck truly "stock" or not. . .I get codes when I have truck programmed & towing on hot days; do NOT get codes towing on hot days when not programmed. . .FYI & YMMV. . . 07 LBZ
  • Scott16 wrote:
    ...I do know the 06 Chev/GMC Diesels were the last year with out any Emission systems.
    Best of luck,
    Scott
    07 "Classic" HDs were pre DPF too (LBZ version of the Duramax)
  • George H wrote:
    Classic or DEF model? Emission changes make these unique.
    2007 isn't the DEF model. DEF didn't come along until 2011 model year.
  • With that combination of codes, I would first check the fuel pressure.
    When did you last change the fuel filter??
  • Hello,
    Mine 2007 LBZ. It gets a 2563 code also. Took it to a diesel shop. Cleared the code. They say it could be the sensor, vane or turbo. Going with the cheapest they would change the sensor since its unlikely a turbo problem. The problem code came back few weeks later without changing anything. Then it goes away after about 4 cycles of starting the engine. Been doing that for about 4 times now. Waiting to see it stay on, then taking it to the shop. I see no change in power or MPG. My mileage is 54K. PM me if you find the fix. Thanks
  • Also you might want to check the www.duramaxforum.com
    A lot of posts about the DEF and issues. Don't know when GMC changed over for a 07 Truck. Might be DPF only. I believe the DEF went into the 2012 Trucks. I do know the 06 Chev/GMC Diesels were the last year with out any Emission systems.
    Best of luck,
    Scott
  • Classic or DEF model? Emission changes make these unique.
