DesertDustBunny
Oct 07, 2015Explorer
Thanks guys for your replies..
I actually just got a call back from Pacific Coachworks and found out that they have NO specs on anything prior to 2008 as the original 'company' went out of business. the 'name' or entity (Pacific Coachworks) continued to manufacturer the Tango trailers under different ownership after that and have no previous records of trailers prior to 2008.
Donn, the only 'tag' I've seen so far is a small metal label on the side of the tongue with the VIN number stamped on it.
There is some 'stamped' information on the top of the tongue itself, but it's hard to make out...
I'll have to go through all of the cabinets and see if I can't find the info...or look at the tongue again in case I missed it.
The 2009 Tango 256RKS lists the following specs..
GVWR @ 7400 lbs.
Dry Weight @ 5500 lbs.
Payload @ 1900 lbs.
Hitch Weight 520 lb
Currently we have no way to get it to scales as this would obviously be the most accurate way of getting the weight, but unfortunately our Chevy Tahoe, as much as I love it, just wouldn't be suitable to tow this size of a trailer..(although it did great when we used it to maneuver the trailer around our property and into position lol)
GVWR @ 7400 lbs.
Payload @ 1900 lbs.
Hitch Weight 520 lb
