sportsman 500 wrote:
I will try to keep this as short as possible. My truck is a 2008 Dodge Ram/Cummins 4X4 quad cab. The front end is tight and has been recently aligned. The tires are 285/70R17 Cooper Discoverer AT "E". This truck is new to me with 63k miles and I purchased it with the Cooper tires on it.
Towing I run the tires at 80 PSI and daily driving I have tried different combinations but found 50 front, 60 rear to work the best. I pull a Raptor 3018 equipped with a Reese dual cam hitch that has been properly set-up. I normally run around 1,200lb. tongue weight.
My issue is while driving the truck will not keep a straight line. It seems I am constantly making minor adjustments with the steering wheel. It is more noticeable on the highway. While towing it is even worse to the point where it is hard to tell if it is trailer sway or the truck. 60-65 MPH and it can be a handful! I went back over my hitch today. I flipped the cams and borrowed a set of new bars from a friend with no change. The only thing I noticed is if I go up one link on my chains to 4 from 5 and add some tension it helps a bit but not much.
I am at the point of trying a different set of tires but am looking for some input before I go that route.
I think you posted over in the cummins forum. Its the tires. Try lowering the pressure. I swapped out tires and the wander went away... Then i sold the truck. :(
