sportsman 500 wrote:
Do you have good shocks
Yes. Shocks are in good shape.
I think you posted over in the cummins forum. Its the tires. Try lowering the pressure. I swapped out tires and the wander went away... Then i sold the truck
Yes I did but only got a few replies. I did try lowering the fronts to 50 PSI. It helped a little but the problem was still there. I just wanted more input before I pulled the trigger on tires.
something to read
I WILL definitely look into this!
OP, have you had the ball joints replaced?
Like I said the truck is new to me. The front end is tight and all four ball joints are grease-able so I assume they have been replaced at least once.
Thanks everyone for the great advice! I will be sure to keep you posted on my findings.
Have OE ball joints put back in it. Some trucks don't respond well to anything else.;)
