asking for a friend. Just to get an idea- 250 crew cab with the 5.4 V8 gas.... I need to find out the axle ratio. Any rough idea what they are capable of towing?
Grit, I had one of them 292 2500's. Reality, the way it was setup, a very good truck for what it was. Now 4bbl 454 R3500 flatbed. That was pos. Couldn't carry squat, much less get out of its own way. Unless the trans behind a 5.4 or equal is chewing up a lot hp, a 250-300hp motor should reliably move trailers to 10,000 lbs. At some point in time, you do need more HP depending upon your performance wants and needs.
