huskyfan68's avatar
huskyfan68
2008 F250 with 5.4
asking for a friend.
Just to get an idea-
250 crew cab with the 5.4 V8 gas....
I need to find out the axle ratio.
Any rough idea what they are capable of towing?
  • If the 5.4-6.0 current V8 motors arent powerfully enough for you. I can not imagine what it would have been like 30&40 yrs ago with. 125hp 292/300 CI I6 up front! I have a 255/355 vortec 350 in my 2500. Plenty powerful for the upwards of 10-15k lb gcw I run at. Only real issue, is 4l80e trans is geared too tall in first. A 6sp auto behind it, that would be sweet.
    Marty
    Marty
    30-40 year old trucks s u ked for towing compared to 10-20 year old trucks which leave a lot to be desired compared to new ones.
    Just because you “can” do something doesn’t mean there isn’t a better or sometimes much better way to do it.
  • Grit,
    I had one of them 292 2500's. Reality, the way it was setup, a very good truck for what it was. Now 4bbl 454 R3500 flatbed. That was pos. Couldn't carry squat, much less get out of its own way.
    Unless the trans behind a 5.4 or equal is chewing up a lot hp, a 250-300hp motor should reliably move trailers to 10,000 lbs. At some point in time, you do need more HP depending upon your performance wants and needs.
    Marty
  • blt2ski wrote:
    Grit,
    Marty
    I think part of the HP problem with the 5.4 was it's small bores and long stroke.
  • My brother used to haul fifty head of sheep in an old six cylinder gasoline fueled school bus. It "can" be done, but not with the performance I have grown to enjoy.
  • Will do just fine pulling the full rating, posted by Groover above, as long as you are patient going up hills. For about $1,000 you can have any rear ratio you prefer. 2x if it is 4WD. I would go right to 4.30 and consider 4.56/4.88 depending on service.
