SilverHornet's avatar
SilverHornet
2008 F450 - Black Maxx tuner help?
I just bought a 2008 Ford F450 Super Duty Diesel to haul our new 42' 5er Toyhauler. The Truck has a Black Maxx performance tuner on it, and I have no idea how to use this. I found a manual for the Black Maxx online, but it is just the basics and I don't understand most of what I'm reading.
The check engine light is coming on with an EGR Code that I can clear with the Black Maxx, but check engine light keeps coming back. Also the cruise control is not working, and occassionally I have limited accelaration(gettin on the expressway). From what I have been reading I think these things can all be solved via the Black Maxx, but I have no idea how.
Does anyone else haul a fiver with a F450 that has this Black Maxx Device that could maybe give me some idea how to use this device, or point me to a good tutorial?
I really appreciate any help.
  • Thanks to all for the responses! Being a newbie to both the big truck and the big fiver I really appreciate the input!
    I may have found the fix for this. Found out that there are 3 Tunes (tuning packages) that are predefined to select from. Found my way through the menu and installed the MILD tune, then it prompted me for a transmission tune which the middle one was pre-selected so I chose it.
    Seems to have solved the problems, I have consistent power now, no check engine lights, and the cruise works! And I have some amazing power now... this thing is great!
    I will drive on it for awhile and follow up to this post in a couple weeks with my experience.
    Scott
  • Do you still have an egr?
    try going to the H&S web site. great forum, probably some good help there.
  • I would go to a Ford forum like Ford-Trucks(FTE). Getting answers about tuners here is typically not a good idea here as most run stock and cannot give you advice other than above. There is nothing wrong with that tuner if used reasonably.
  • If you have a failing EGR please get it fixed immediately...horrible things can happen to the 6.4 when the EGR fails...can make a 6.0 failure look like a walk in the park.
    I highly suggest removing the tuner as well....
    It's just not worth it
    Thanks!
    Jeremiah
  • First thing I would do is 'remove' that programmer/tuner---go back to 'stock' and see IF issues go away or still exist.
    Then resolve issues IF they aren't caused by programmer/tuner
