Lantley wrote:
Halmfamily wrote:
That's a great truck, see my sig.
This truck truck does not use DEF but runs a regen cycle every 500 to 800 miles depending on your driving. I'm averaging 16 mpg bobtailed and 8.5 to 9 towing my 42' fifth wheel. You'll notice a drop in fuel economy when the regen cycle is running. I have a Scan Gauge II on my truck and can tell when the regen is in progress. You don't want to shut the truck off when its running the regen. The turbo pressure will be low when it running the regen and egt temps high. Run the truck hard and it will take care of you.
It's an awesome truck, reliable and powerful. I'd snatch it up because they are hard to find in my area, at least.
The low towing MPG speaks to the issues of the early DPF trucks.
While they are OK trucks. The 1st generation DPF trucks suffered from poor MPG's. I would prefer a later model year 2011 or newer. DEF was introduced by then. The frames/suspensions were also beefed up and payload ratings where increased.
The manufacturers learned from their mistakes. Diesels of the era were OK. However the next generation was a drastic improvement. Emission technology improved and so did MPG's
I consider the 2008 era the learning curve period when it comes to diesel emissions.I would avoid diesels of this era simply because better emissions technology has produced better more efficient trucks since then.
Complexity isn't always better. The first def trucks had many teething problems. Still are with a 9th injector recall.
