brulaz
Sep 29, 2013Explorer
We like this type of floorplan. For a short 27'3" trailer with a mid-bath, it makes lots of sense to open up the bath a bit to make the bedroom more open. We also like the dinette curbside (campside) with a sofa in the slide facing the dinette. There's lots of kitchen counter space.
This Cougar has 4400# axles with Paco I-beam frames and ST225/75R15-D tires. These give you lots of reserve capacity for the 7200# GVWR.
They also have good ground clearance and some 4-season capability. Not sure about this one, but you can order them with Dual Pane thermal windows.
The 24RKSWE is a Western model (made in Oregon?). Compared to the Eastern Cougars, it has a very good tank volume (fresh, black and grey).
What I don't like are the "hung" front and rear walls. They are not laminated like the side walls. Probably not a big deal, but I would prefer a fibreglass front cap (like the Eastern models) and a laminated rear wall.
As for construction quality, I haven't looked at one carefully. But the Eastern Cougars are only ok IMHO.
You are from Oregon. Have you considered Northwood Mfg. or Outdoors RV Mfg.? They make several brands of trailer, some with similar floorplans, all manufactured in Oregon. In particular, there's Outdoors RV Creekside 23RKS. But also the BackCountry 23FS and Timber Ridge 240RKS. Northwood makes the Artic Fox 25P (a very heavy duty unit though).
