philh's avatar
philh
Explorer II
Jan 01, 2019
2010 Ford Super Duty
6.4 Diesel 4wd, 134,000 miles, looks in great shape. Has an aftermarket fuel tank in the short bed, also selling with a hitch.
Anything I should be looking for?
  • Aside from it's other proven problems, the 6.4 is known for terrible fuel mileage. As stated above, move up a year or two and look for a 6.7. you will be glad you did.
  • If serious then take it to a certified diesel mechanic/shop/dealer and get a full inspection. Then buy an extended warranty from Ford ESP.
  • If the issues have been properly addressed, EGR, head bolts and up pipes, all will be good, which is why I'd want to see the service records and / or do an oil analysis. No records, no oil analysis, no buy.
  • The 6.4 was almost as bad as the 6.0. Either go older with a 7.3 or newer with a 6.7.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Lynnmor wrote:
    I would look for a slightly newer truck with the 6.7 and leave all those 6.0 & 6.4 issues behind.
    X2!
  • If you have to ask, then don't buy it. Great truck, not so great engine.
  • I would look for a slightly newer truck with the 6.7 and leave all those 6.0 & 6.4 issues behind.
  • Service records. At the very least, I'd pull an oil sample and send it off to Blackstone in Fort Wayne and get an oil analysis done before buying. That will tell you conclusively if there are internal engine issues. If it's an automatic, I'd do the same with the fluid, even if it don't appear burnt (brown and stinks if burnt).
    If the owner balks about an oil analysis, I'd walk away because something is fishy.
    Oil analysis keeps everyone honest.
