SoundGuy
Jul 14, 2017Explorer
datric.johnson wrote:
I have a 2010 Chevy Silverado 5.3L V8 6spd. 2x4, 3.08 axle ratio. GVWR: 6800lbs. I have the weight distribution hitch which is rated up to 10500 lbs. I also have the engine oil and transmission oil coolers.
If your truck truly has a 3.08 axle that's a real limitation for towing. :( My current 2012 is similar to yours but it does run a 3.42 axle which works well enough towing our 4700 lb couple's trailer but would certainly do better with a 3.73 - no way though I'd want to tow with a 3.08. :(
