kaboingy's avatar
kaboingy
2010 Toyota Sequoia towing capabilities
Can someone help me? I am new to this whole trailer thing. We have a 2010 Sequoia. We are wanting to get a Forest River hybrid 233s. Here are the specs for it.
GVW: 6,780
Dry Weight: 4,670
Payload Capacity: 1,870
Hitch Weight: 590
We have 5 kids so we would be towing with 7 passengers in the vehicle. Can we tow this trailer with our sequoia? We would use a Equalizer hitch.
I feel like I am trying to learn a foreign language trying to figure this all out.
Here is our door jam sticker with specs...
  • Welcome to the Forum.
    Let's put first things first. Load your Sequoia just like you would be loading it as a tow vehicle.
    This means minimal luggage, that should be in the trailer. So take you and your family...iPods, toys, etc...the stuff you take on a trip.
    Fill up the SUV at a gas station with a CAT scale and weigh it with you and your family in the SUV after you fill up.
    Should cost you about $9.00
    Also, the tire loading sticker is specd at 33 PSI...your tires are going to handle 44-50 PSI... While towing..air them up to the max PSI on the side wall. This will make the truck feel more stable while towing.
    Do this and post back with the numbers from the cat scale.
    Thanks!
    Jeremiah
  • Welcome to the forum !
    First is to decide if you believe in the ratings systems or not
    If not, then do whatever but know you have taken the OEMs off the hook for
    warranty and liability
    If yes, then read and learn HOW2
    Next is to load up your TV as if going to tow and weigh it axle by axle
    That will then tell you where you are in reference to 'your' vehicles ratings
    All classes of TV's can be over their ratings, but the lowest class gets into
    over weight trouble sooner or with smaller trailers (fiver and TT)
    Depending on the weigh of your family, pets and cargo...betcha will have little
    room for the tongue weight. Might not have enough for a popup
    Am of no help until you provide actual weights of how your TV will be loaded up
    ready to go camping
    PS...kids tend to grow and another question is how long do you keep
    your vehicles? Also, many advisors discount babies and toddlers...forgetting
    all the 'stuff' that comes along with them... :B
  • You are limited by the payload of 545 KG or 1200 pounds. That includes everything carried in the truck: passengers, weight of the hitch, dogs, luggage and whatnot. When that trailer is loaded the hitch weight will be closer to 900 pounds which leaves you very little weight left over for stuff in or on the truck. You are running up against the big problem with all the import trucks.
