Ron3rd wrote:
otrfun wrote:
JohnG4706 wrote:
I've found a couple of 2010 Sequoias in my price range. The following questions:
And, in the long run, the Flex Fuel is more expensive when compared to gallons used vs distance. Would being Flex Fuel compatible have any effect on my MPG's if I stay with unleaded only.
The oil change intervals on many of the 5.7 Tundra/Sequoia FFV's (flex fuel vehicles) are twice as often as the non-FFV 5.7's---even if you don't use a drop of E85. Toyota made some significant changes to their maintenance intervals and oil specifications around 2010--some changes were even mid-year.
If the FFV vehicles you're looking at are out-of-warranty, then this may not be an issue. However, if they are, then it's something to consider (FFV vs. non-FFV).
Interesting info and worth looking into. My 07 Tundra is not a Flex Fuel truck and I'm not familiar with the newer ones. I change my oil every 5,000 miles.
Can't remember the specific OCI's on the earlier model 5.7's. But, I do know the 2012-2013 NON-FFV 5.7's have a 10k OCI (oil change interval). The 2012-2013 FFV 5.7'S have a 5k OCI even if you don't use a drop of E85. If you do use E85 for more than a certain percentage (50%???) the OCI drops to 2.5k!! Lotta debate on various Toyota/Tundra forums as to why, but there's no clear consensus.
