- MTPockets1Explorer
ljr wrote:
same, no difference- did mine in March.
I just got it a few days ago. Didn't notice any problem before or after. - stsmarkExplorerMines been normal for the last 3 weeks since update. Skyhammer, I live in Windsor north of Santa Rosa. Diesels get a OBD2 interrogation and mod inspection plus a snap throttle smoke test. 8 miles north they don't even test cars.
- JustaguyExplorerWell....had mine done last week. So far so good.
- skyhammerExplorer
stsmark wrote:
Mine was done on Tuesday and seems fine. My dealer gave me a slip for the DMV renewal as well. I've had my 2011 4 years now and have not had to take it for a Smog check yet, my 2001 went every 2 years like a car.
I don't know where you live, but in my part of N.Calif. We don't have smog checks. - GoPackGoExplorerMy 2013 was done last Feb. No problems at all. No impact on mpg or DEF mileage that I can see. I do concur with Lumpty about the trans shifting smoother. The other thing I noticed is that it seems to run a little better when cold, especially when in first gear.
- LumptyExplorerHad it done a few months ago. It changed lots of things under PCM/ECU control. I'd just say it drives "different". Mileage is pretty much the same. The two really noticeable drivability items from the reflash are that at highway speeds, it is much quicker to downshift out of 6th instead of building boost and torque to increase speed if throttle is slowly applied; the other is that the transmission has much softer shifts. Not old E4OD mushy, but enough that even my wife noticed the difference when she drove it.
- Mine done in Feb. No problems nor notice any difference.
- Chilly-in-VermoExplorerI also had the DEF massage "800 miles to empty" and mine also only took 2 gal. Other than that no issues at all to include mileage.
- RedRocket204Explorer
BenK wrote:
My biggest concern would be that it doesn't 'break' it right away, but
under certain conditions...it might act up...or go into limp mode...or
stop the vehicle or kill a component on the spot...
I'm curious, since you don't own one of these trucks, why this is a big concern for you? - txduttExplorerhad mine done a few months ago---only thing I noticed was the DEF was saying 800 miles to empty immed after the update---only took 2 galls to fill it up, no issues with it since then
44,066 PostsLatest Activity: May 16, 2026
