APT
Jul 27, 2014Explorer
br549redneck wrote:
Go to a 3500 SRW for 500 more lbs of payload?...
no, 1500 pounds. GVWR goes from 10,000 to 11,500...
Vehicle Series Hitch Type Maximum Tongue Weight
2500HD Fifth-Wheel Gooseneck 1134 kg (2,500 lbs)
3500 Single Rear Wheels Fifth-Wheel Gooseneck 1360 kg (3,000 lbs)
What you listed from the owners manual is not payload, it's pin weight. As mentioned GVWR does up 1500 pounds, so payload probably 1450 of that. Extended cab 4WD diesel GM has about 2600-2800 pounds of payload. 2WD 300 pounds more. So if you have 3000 pounds of payload with 2500 pounds of pin weight, what about the 250 pound receiver and two overweight adult males?
SWR 3500 is my recommendation, but they are harder to find usually. Many people just plan on air bags and 3/4 ton because the power is plentiful.
