br549redneck's avatar
br549redneck
2011 Chev silverado 2500 2962# capacity updated
Looking to purchase the above truck 2011 silverado 2500 ext cab LT diesel. Payload 3200# towing capacity 17,000#. I am wanting to pull a 28'-34' 5th wheel. Just guessing weights around 12-14K will I have enough truck? Anyone towing with the 2011 2500 ? This will replace the low towing capacity of my 2011 ram with the 5.7 hemi and 3.73. Thank you for any input you have to offer.
Mark
  • Those numbers are max payload and towing for a 3/4 ton.
    My crew cab 4x4 has 2,550 payload (door sticker)and 15,300 towing a GN or FW. Bumper pull drops to 13,500 with 1,500 lb hitch weight.
    The payload and towing numbers can be found in the owners manual. It has a break down based on configuration. The ext cab will have higher numbers than mine. I think it would have to be a 2wd gasser to get that kind of payload.
  • According to the manual king pin weight max is 2500#. Let me ask a question with looking at some 5th wheel trailers whether it be on Heartland, or Jayco's web sights how can I determine/estimate the kingpin weight on theses coaches? Say for this coach.
    Jayco 28.5RLTS | 2014 Eagle Touring Edition. "Per Jayco's web site"
    Unloaded Vehicle Weight (lbs) 8,310
    Dry Hitch Weight (lbs) 1,760
    Gross Vehicle Weight Rating (lbs) 10,500
    Cargo Carrying Capacity (lbs) 2,190
    I do understand pin weight will vary with actual gross vehicle weight.
  • You'd do better to go for a dual rear wheel 1 ton. 3/4 ton trucks will pull the weight, but they really cannot handle mega high pin weights.
    I have a 3/4 ton diesel crew cab, and I'm limiting myself to 2K pin weight and 11K total dry weight.
    So many of the full size fivers, like Montanas and Big Horns, really need duellies.
  • I would tow that trailer with it.
    But if I was going to be towing it a lot or if the width of a dually was not going to be a disadvantage I might go with a dually.
    From a weight police (the WP on this site not the real DOT officers) point of view you might be over or pushing it or over on payload but I really doubt you will be over your axle weight ratings.
  • It will pull it, though you might want to invest in some air bags for the rear axle.
  • Power no issue, where did you get the payload info from? if from a brochure, the payload is probably less than that. If off the door sticker, then that payload is what you have.
    Marty
