- ksssExplorer
rsaylor3 wrote:
Great time for your post. I have 8,500 lb loaded travel trailer. Box is 32 and 36 overall. Currently pulling and have been for one year now, with a 2013 Silverado 1500, with 5.3 and 6 speed. I live in Florida and 5 of our trips were in state, the other two were at stone mountain in Georgia. We are planning to buy a 1 ton this year. Was leaving only to diesel power until the last couple of weeks. I have started to think about the extra cost and whether or not I can justify it.
Right now I usually lock it in 4th manually and put it in tow haul mode. Anything steeper than a quick standard over pass and its down shifting to 3rd to hold 63-65 on cruise. Going to Georgia I spend a good amount of time in 3rd.
Seems like from reading this thread that I might be alright in a 6.0 Gasser Silverado.
What could I expect upgrading to the 6.0 in my Florida travels and the smokies that we plan to hit this fall.
Thanks
I would hold off for a couple months. I keep hearing these rumors of a HD 6.2 being offered in the HD GM trucks. This is supposedly coming for 2017. If that is true I think we should start seeing whether that is in fact what is coming soon. Normally the new model year trucks start production in July. The 6.0 is a great motor, likely one of the best gas engines built. I think the HD version of the 6.2 could be every bit as good with considerably more power than the 6.0 I would like to see a confirmation on this from GM, have not seen that yet. - RCMAN46Explorer
rsaylor3 wrote:
Oh and I forgot to add that I have 3.42 gears.
Your header stated 3.73 gears.
But what I said still holds true. In fact the overall ratio with a 4.10 vs 3.43 will be very close as you go down in gears.
By that I mean 6th gear with a 4.10 will have a very close overall gearing as the 3.42 will have in 5th gear and so on as you go down in the gears on the 6 speed transmission. - 45RicochetExplorer
Turtle n Peeps wrote:
Barney make this post a sticky! ^^^^^ :W
Who is Barney? the nut on the towing side?
I lost his forum years ago for being bias.
And that's being polite.
He was a down right rude old dude who reminded me of a relative I had to see each Christmas.
Now if your talking Andy and Barney I'm good with Maybery. - rsaylor3ExplorerOh and I forgot to add that I have 3.42 gears.
- rsaylor3ExplorerGreat time for your post. I have 8,500 lb loaded travel trailer. Box is 32 and 36 overall. Currently pulling and have been for one year now, with a 2013 Silverado 1500, with 5.3 and 6 speed. I live in Florida and 5 of our trips were in state, the other two were at stone mountain in Georgia. We are planning to buy a 1 ton this year. Was leaving only to diesel power until the last couple of weeks. I have started to think about the extra cost and whether or not I can justify it.
Thanks - Turtle_n_PeepsExplorer
RCMAN46 wrote:
There is nothing wrong with operating in third gear. That is the whole purpose of a transmission.
A 4.10 reared will not give you anymore horsepower than a 3.73.
Gears do not increase power output.
You will find with the newer 6 and 8 speed transmissions the truck will be able to pull the hills at virtually the same speed with either a 4.10 vs a 3.73.
The only difference the 3.73 may require one gear lower but that is the purpose of a transmission.
The 6 and 8 speed transmissions have gearing that will keep most gas engines in their peak horsepower rpm range.
Good gravy!!!! Someone gets it!!!!! I can't believe it!!!
Barney make this post a sticky! ^^^^^ :W - RCMAN46ExplorerThere is nothing wrong with operating in third gear. That is the whole purpose of a transmission.
The 6 and 8 speed transmissions have gearing that will keep most gas engines in their peak horsepower rpm range. - kw_00ExplorerStruggle? Nope I pull 10k with mine and don't have an issue. U will spend some time in 4th or even 3rd gear, but never will the truck struggle or blow apart or die along side the road... It's all about perception, I have pulled with gas and diesel and chose gas. With the 6 speed u will notice a much improvement in how the power band is used verse the older 4 speed models.
- ksssExplorerIt wont be an issue. Pulled twice that at higher elevations than Yellowstone with the same setup. Gas is cheap, excepted in West Yellowstone.
- SouthpawHDExplorerWhen the RPMs go up, turn up the radio and just keep cruisin :)
44,043 PostsLatest Activity: Jul 20, 2025
