Huntindog
Dec 12, 2013Explorer
720Deere wrote:Nothing to go on other than the facts that at about the same time Ford started having radiator problems, they also started having the coolant issues.. Makes no sense to me as the Ford radiator is a common design that all of them use.
Where do you guys come up with this foolishness that testing the coolant has anything to do with the radiator failures? It is all about nitrites which can affect head gaskets and many other internal parts but it has nothing to do with the plastic radiator tank failure.
You Dmax guys may want to read up a little before you crow too much. Our fleet of Dmax powered pickups has experienced quite a few head gasket issues and the general consensus has been that the coolant was not properly maintained. All modern diesel engines are sensitive to nitrite formation in the coolant and vulnerable to subsequent problems. It is far less of an issue with the Cummins, but they are not immune.
The common factor is the coolant. And since Ford is very specific on stringent maintainence/testing for their coolant... It seems that Ford is thinking along the same lines.
44,056 PostsLatest Activity: May 04, 2014
