Grit_dog
Feb 24, 2020Trailblazer
F5Pro wrote:
Good point. I looked at the tires on my F150 and it said about the same thing: max load pressure was 80, but the truck didn't say that-only 35 front and rear. I haven't seen the 350 yet to compare. Thanks.
Nothing to compare. The "sticker" on the door is going to be for max load and say 80 psi or something close. Unless the truck has the wrong tires or big wide tires (not likely on a 2wd), they too will say 80psi (possibly 65psi but not likely).
But the truck doesn't weight "that" much more than your 150 that you apparently have D or E load tires on, so weight vs load still applies the same whether it's on a F350 or something from Uzbekistan.
44,066 PostsLatest Activity: Jul 25, 2018
