SabreCanuck
Jun 16, 2015Explorer
Update - weird one.
Called dealership to discuss options, he asked me to remove the switch and check for power, which I did. Had power at switch, started thinking it was the motor but wanted to test to make sure the 'on' switch was working. So I 1/2 plugged it in and tried testing with my test light to make sure there was power travelling through switch.
Accidently touched (spark) two of the plugs at same time and when I did I heard the motor blip. put down the test light and tried the switch and the slide comes in/out as normal.. Tested about 10 times and all is well.
Weird... But, I now have the required adaptor for manually bringing slide in. :):):)
44,056 PostsLatest Activity: Nov 19, 2013
