Bears_Den
Jun 19, 2015Explorer
I had a problem with mine that turned out to be a loose wire. On my trailer tongue are two selonoids that run between the battery and the slideouts. The wires were loose on the selonoids and when they were tightened up the slide worked. Not sure if yours is set up the same way but it is something to look into.
44,056 PostsLatest Activity: Nov 19, 2013
