wrasse
Jan 20, 2014Explorer
If tires are the limiting factor then why does 2013 SRW (essentially same truck) have this rating?
2013 SRW Ram 3500 Megacab, payload of 4410 lbs, max trailer of 16,840 lbs
Both 2011, 2013 have E (not G) rated tires.
donn0128 wrote:
You will overload the rear tires long before you run out of power. A 17K fiver is going to have 3500-4500 pounds of pin weight. About 95% of that weight will be directly over the rear axle. Get something smaller or get a dually.
44,066 PostsLatest Activity: Jul 25, 2018
