donn0128
Jan 20, 2014Explorer II
wrasse wrote:
If tires are the limiting factor then why does 2013 SRW (essentially same truck) have this rating?
2013 SRW Ram 3500 Megacab, payload of 4410 lbs, max trailer of 16,840 lbs
Both 2011, 2013 have E (not G) rated tires.donn0128 wrote:
You will overload the rear tires long before you run out of power. A 17K fiver is going to have 3500-4500 pounds of pin weight. About 95% of that weight will be directly over the rear axle. Get something smaller or get a dually.
Trailer payload is not the same as fifth wheel pin. And this is based on a lot of factory, tires is only one of those factors.
It sounds like your going to do it regardless what anyone says, so go for it. Just don't come back here in a year or so and complain about problems.
44,066 PostsLatest Activity: Jul 25, 2018
