NC_Hauler
Jan 24, 2014Explorer
Redsky wrote:
GCWR takes into account the total load that will be placed on the engine bearings, U-joints, transmission, and frame of the truck. That is why lower gears provide a higher rating - something that should be obvious. The diesel engines can take more stress than the gas engines and so the same gearing will provide for a higher GCWR with the diesel pickups.
Hard to understand why NC Hauler cannot get the difference between the calculated load rating for a stock truck as it left the factory and one that has been modified with new tires or other components. It takes 10 minutes on any dealer's lot to look at 1-ton pickups and see very different payload ratings and then to compare the trucks and see that the only difference is in the rims and tires on the trucks as they were ordered by the dealer.
My truck came with tires rated at 3200@80 PSI for a 6400 lb. load capacity. The GVWR is 6700 lbs. but I would not have that amount of load and expect not to have problems with the tires. The axle and wheel bearings are manufactured by AAM and this company's engineers rate the axle and its wheel bearings at 10,900 lbs. and I would think they know what they are doing. The same axle that is used on my Duramax 2500 is also used on the 3500 trucks that show a much higher payload. ONLY two differences the 3500 trucks, an extra set of leaf packs and an extra pair of rims and tires. Go figure!
Just overlook me, I'm not real bright.....you are correct...again, I'm human and will make mistakes..There are a lot of things I don't "get" and at almost 64, I'm "not getting it" more and more.....please ignore my stupidity. ........sorry.
44,066 PostsLatest Activity: Jul 25, 2018
