wrasse's avatar
wrasse
2011 Ram 3500 Mega SRW 5th Wheel Towing 17K?
I currently have a 2011 SRW Ram 3500 Megacab with cummins 6.7 and looking to purchase a new 5th wheel toyhauler. The size I'm looking at 34-36ft will likely have a wet/loaded weight approaching 17,000 lbs.
I fully understand DRW is best but it's not an option for me as this is a multipurpose truck and I live in a crowded city.
According to factory specs...
My 2011 SRW Ram 3500 Megacab has payload of 2600 lbs, max trailer of 12,950 lbs
Interestingly the 2013 SRW Ram 3500 Megacab (basically the same truck frame, axle, brakes, rear tire rating) has payload of 4410 lbs, max trailer of 16,840 lbs
According to cummins forum guy, the changes from 2011-2012 to 2013 Ram were
Originally Posted by Jim W
The engine and torque converter were redesign for the 2103 model year. New cooling piston jets, a redesigned piston and if I remember correctly a new bed plate was added. Also the cooling system was redesigned to improve cooling; dual radiators, a redesigned charge air cooling upgrades along with dual transmission oil coolers. So the tow ratings were improved over the 2012MY by these changes. This was made very evidently to us at the CMEP plant when Cummins/Ram held the rally in June 2013.
None of these changes were to the frame, rear tire rating, axle, brakes, etc, yet the factory tow rating on the 2013 jumped up by a huge margin.
So it's a little confusing if it's worth the upgrade to the 2013 model or if it's just a marketing gimmick and the 2011 model tow rating was under rated.
I am thinking I am ok to go for it with my current truck but wanted to get more thoughts on people who have actually towed this weight with a similar SRW 1 ton truck.
  • You will overload the rear tires long before you run out of power. A 17K fiver is going to have 3500-4500 pounds of pin weight. About 95% of that weight will be directly over the rear axle. Get something smaller or get a dually.
  • "My 2011 SRW Ram 3500 Megacab has payload of 2600 lbs, max trailer of 12,950 lbs"
    Max trailer 13K and considering a 17K trailer because a different year model has different tow ratings.
    That would be like using the ratings of 2009 and only having 10,000 tow rating
    17K trailer is DRW territory. JMHO but yours seems different.
