HRcampers's avatar
HRcampers
2011 Ram brake issue?
After our holiday weekend trip camping, upon exiting the interstate, I applied the brakes and heard a loud low-pitched drone coming from the rear of my 2011 Ram 2500. The sound would continue for a couple feet after releasing the brake peddle.
After entering the storage yard to drop off the trailer, I had my son get behind the wheel so I could pin point the location of the sound. It was definitely coming from the passenger rear. The wheel and hub cap were considerably warmer than the other side. When the brakes cooled the noise was gone.
I have tried to reproduce the sound during the week. If I take it on the interstate for a few miles and then exit, I can get the noise to come back, but not as loud as when the camper is hooked up. A couple days driving to work this week, the noise has been non-existent.
I am suspecting a seized brake caliper. The other day after the truck was parked for about 45 minutes, I went out and touched the front surface of the rotor and it was still hot to the touch, the other side was air temperature.
The truck is going into the dealer Tuesday for the tie rod recall and for this brake? issue. My concern is that if the tech drives it and cannot reproduce the noise, I will leave the dealership with the same problem. Is there a way a tech can diagnose caliper? by sight alone? I did crawl under there and noticed that the rubber dust seals around the caliper pistons are distorted and not the same shape as the other side.
Anyone ever run into this? Any info would be helpful. Thanks!
  • I had the same thing on my 2011 only on the drivers side. The service writer knew exactly what it was when I explained it. The caliper was hanging up and was replaced. Now for my tie rod ends.
  • If the caliper is hanging up all you need to do is jack up the rear end put the truck on jack stands then rotate each side (truck in neutral). The drag for force it takes to rotate should be the same on both sides. I would also look at the parking brake and make sure the cable going to the brake shoes is free. There should be a little slack between the cable and the arm.
    Don
