intheburbs
Sep 11, 2017Explorer
SidecarFlip wrote:Ralph Cramden wrote:
I have had the 6.0 in 3 different 2500's, 2007, 2013, and 2015. I tow a 5+ mile long grade often, at least a dozen times a season, on the way to a PA state park that exceeds 9% for the most part pulling 6000 lbs or better. I have only seen transmission temps above 200 pulling that grade a few times, around 205, and that was when ambient was in the low 90's.
Usually temps are between 165 and 185 pulling that grade. I also am not babying the truck when doing so, 50 to 65 mph wound out @ or above 4500 rpm.
Playing race car driver huh?
Blowing that carbon out of the exhaust system.........:E
Are you even aware of the specs on this engine?
SAE horsepower, hp @ rpm 352 @ 5400
SAE torque, lb-ft @ rpm 383 @ 4300
So that means the optimal power band is between 4300 and 5400. So what's the problem?
