navybanker's avatar
navybanker
2012 Duramax Engine Heater
I just purchased a 2012 Chevy 2500 and trying to locate the engine heater you plug into a 120 house outlet. The temp is supposed to be close to zero next week. The manual says it is located on the passenger side near the aux battery. I haven't located anything thus far that resembles a cord to "unwind'. I doubt the previous owner needed it in these parts. There is a wire/hose? doubled up next to the DEF filler cap but not sure enough to attempt to pull it out!
Thanks,
  • The heater in your Duramax will not work above 0 degrees.
    Mark
  • I used the preheat plug on my '04 traveling in Colorado and Nebraska some years back. But I never used it in Tennessee. Just thought this might be good insurance since the high one day next week is forecast to be seven. It should be easy to spot but not so far. Maybe this truck was built in Mexico!
  • Its on the passenger side, just keep looking. Also as stated above its not neccasary but does help with quicker warmup. I have a 2011 and have started mine at 20 below without plugging in.
    Thanks,
    Just to put your mind at ease...My 2006 Gold Standard DuraMax has never been plugged in...This morning, sitting outside in the driveway in -3F temperature, it fired right up...
    Regards
