3oaks wrote:
mbopp wrote:
Tow rating is meaningless on a 1/2-ton.
Ridiculous statement! :R
It is one of several factors that must always be considered when calculating the towing capacity. :@
Not necessarily when it comes to 1/2 tons.. I had the same truck as the OP and my trailer is 32' long and 7800lbs loaded. With the trailer attached and the family and gear in the truck I was right at the trucks GVWR. And I was still 3,400lbs under the max tow rating..
To the OP, If that trailers dry weight is 8830lbs then unfortunately you will be well over your trucks GVWR and more than likely over the rear axle rating too.
