Greene728's avatar
Greene728
2012 F-250 Gasser tire PSI
If this has been discussed please forgive me. I did a search it didn't find much specific to my TV.
I have a 2012 F-250 CC SB 4x4 with a new set of Toyo Open Country AT's. I have recently replaced the shocks with Bilsteins and they definitely helped. But it's still a very rough ride. I'm well aware of the fact that number one it's a gas truck and its lighter and will ride differently than the 05 diesel I came from. And number two its a 3/4 ton SD truck and not going to ride like a car.
But....it's rough! I have played around with tire pressure's some and its helped. But in order to get a half way decent ride, I have to drop them into the mid 50 psi (not loaded or towing) range which sets of the TPMS. The tires are LRE with a 80psi max rating. Right now I'm at 65psi on all 4 corners to shut up the TPMS and for towing the 5th which weighs in at around 9500# loaded and ready.
So my question's are... What are you guys with similar rigs running? Can I reprogram the TPMS to accept a lower psi when empty (don't see anything about this in the manual)? And could it just be I selected a hard tire (after extensive research, and toyos being highly regarded)?
I of course will readjust pressures when planning to tow/and haul as this isn't a problem having a compressor in the shop. I know I want my cake and eat it too, but when the DW ain't happy with the ride....well you know the rest!
Thanks,
Scott
