R12RTee wrote:
carringb wrote:
It's a fantastic truck. Even with the Allison its rated for 80,000 pounds combined. Fuel economy of the auto is pretty comparable to a Dodge 4500 with the 6.7L.
One thing to look into however is maintenance costs. PMs are pretty involved, such as periodic valve adjustments. It is not a driveway job. So just be aware that those costs are there, and will be higher than other comparable motors.
Thanks. As a full timer my driveway maintenance has been largely curtailed but are valve adjustments needed all that often?
What does the Dodge 4500 with the 6.7L get for fuel mileage?
No I thought we established valves are done at 500,000 ? many go longer .
The reason I asked if it has a Allison is the fuel economy will be effected ,not so much by the torque converter as by fewer gears in the allison vs a automated manual.
