troubledwaters
Apr 20, 2017Nomad
Depending on the slide, yes there very well may be a reset. In order to know for sure, you'll have to find the "Controller", if you have one. Mine is a black box, underneath the refrigerator, in a panel that you have to remove. The panel is not normally removable but is only held on with a few small staples. The only way I found the controller was taking off the removable panel next to it (for the water heater bypass) and sticking my head in there with a flashlight. Until you find that controller you won't know what to fix. If you knew the make, model, and type of the slide it was be easier to figure out how to help you.
