3_tons
Apr 01, 2014Explorer III
Starting out with Supersprings sway stops (to engage overloads - helps sway condition), I added two extra leafs per rear side in the primary pack and sag forever no more. Truck is a 2007 3500 4x4 DRW Dodge CTD Quad cab...Even with about 55gals water aboard, full of fuel, 4,900# camper (when fully stocked), and with 40" stinger and several hundred pounds of trailer tongue weight (16'x7' cargo), truck will not sag. Spring shop said spring capacity now exceeds a 4500 series and surprisingly ride without TC is only slightly stiffer than is a stock 3500. With TC aboard ride is fantastic - you might well forget that TC is even aboard with or without loaded trailer tongue weight. In my current view other remedies are half measures.
Best Regards,
3 tons
Best Regards,
3 tons
