Bedlam
Apr 02, 2014Moderator
mooring product wrote:
I also notices stable loads has two part numbers (one with drill bites and the other without.) for ordering. The one with drill bits is $50 more....couldn't I just use my own drill bites?
If you do not have a quality bit to drill through your leaf spring, expect to spend much more time sharpening or replacing the drill bit to get through that spring steel. You may be able save some money on the bit, but you will have to decide what time your time is worth and your patience level.
