mooring_product
Apr 03, 2014Explorer
jmckelvy wrote:
I'm curious since you have a 3500 dually how much "sag" do you have when loaded. I'm somewhat surprised. I also have a 3500 dually. The only suspension mods are Stable Loads and a sway bar. My truck drops 3 inches measured at the rear axle when my AF 990 is loaded and full. I don't find that to be a problem. This camper is probably quite a bit heavier than a Lance 881. Do you have more drop.
The 881 Max is 3300 pounds dry weight. We must be very close to the same weight. My truck is a shortbed....so is the 881, putting more weight to the rear then a long bed setup.
I would say my drop is 3" also maybe a little more when loaded with water.
Thank you for your services.
